danysnipe
Oct 15, 2016Aspirant
A6210 not recognised by pc and genie
I just bought the AC1200 A6210 usb adapter. The adapter does not get recognised by the pc and genie. when I install the drivers and it ask me to plug in the adapter, it doesn't recognise it. And i ...
Fredje
Nov 09, 2016Aspirant
Hi all,
From Support I have got a new beta version of the driver software. (WIN10-27-TRIAL version) This package will recognize the A6210!!
But I still have problems with the connection on the 5g WIFI band.
So, there is still some work to do by NETGEAR
Hopefully they soon will issue a better driver as wel.
I will inform Support about my findings as well
Fred van der Ham
- Aikon94Nov 10, 2016Aspirant
Same problem here, Upgraded wifi adapter from a tp-link low price **bleep** to this hoping it would have worked better but nope, can't figure out how to make it work with genie, and the connection is not stable at all even using usb 3.0. Going to return this product if i don't get answer fast.
- Aikon94Nov 11, 2016Aspirant
UP!
