danysnipe
Oct 15, 2016Aspirant
A6210 not recognised by pc and genie
I just bought the AC1200 A6210 usb adapter. The adapter does not get recognised by the pc and genie. when I install the drivers and it ask me to plug in the adapter, it doesn't recognise it. And i ...
Janvdb
Oct 21, 2016Aspirant
Hi,
After updating to 1.0.0.35 software I have the same problem,
Wifi Drivers work ok but A6210 is not foud by genie software.
Latest windows 10 home software and USB2 ports.
Tried deinstalling reinstalling with firewall and Virus scaner off but still no result.
Deasel
Dec 04, 2016Initiate
OS: Windows 10 with latest updates
Just like Janvdb, everything was working perfectly until I was prompted to upgrade to v1.0.0.35, now it doesn't recognize the adapter regardless of switching USB 2/3 ports (they all work with other devoces), uninstalling/reinstalling etc. It appears this latest upgrade was actually a "downgrade" rendering the adapter as completely useless.
Here's an idea, instead of having every user private message the moderator, how about posting the solution so others can come here and have the benefit of fixing the issue, or is this issue unfixable?
