danysnipe
Oct 15, 2016Aspirant
A6210 not recognised by pc and genie
I just bought the AC1200 A6210 usb adapter. The adapter does not get recognised by the pc and genie. when I install the drivers and it ask me to plug in the adapter, it doesn't recognise it. And i ...
Piledriver
Feb 24, 2017Aspirant
Hi Guys
Can someone please help i have the same issue which seems to be affecting everyone, A6210 not being recognised through Windows 10
frustrated? you bet another 24 hours of this and its going in the bin. Thanks
- ElaineHFeb 25, 2017Initiate
why is the answer not posted in the forum? Why do we have to PM someone and why are they selling these devices if they can't be used. I'm really angry that I have wasted hours of my time and $90 :manfrustrated:
- JanvdbFeb 25, 2017Aspirant
The apdapter does function on my pc with windows 10 after applying the fix sombody else sugested on this forum.
When the installation fails with the error, abbort it.
Then find the directory where the installation files are extracted.
this dir contains three files A6210_v1.0.0.35.exe, A6210_v1.0.0.35_Release Notes.html and A6210_v1.0.0.35-Standalone.exe.
the first should install the drivers and a special program A6210_Genie.
The problem is the A6210_Genie program not recognizing the Wifi Adapter.
BUT!!! you don't actualy need this program altough it helps configguring the addapter (in my case worked fine in version 34)
if you start the standalone A6210_v1.0.0.35-Standalone.exe after you did the abbort, Only the driver wil be installed, and you than can do the netwerk configuration trough the windos control pannel, but that takes more expirience than the easy way with the genie program.
That is why i Still think Netgear should fix the problem.
I can't make a service request myselff sice I bougth my adapter more tha a year ago, but if you bought it recently in a store, you should be able to register the device and make a Waranty claim trough the support tab on the website , and get a more direct responce from Netgear
Hope This helps others,
Jan.
- bozzanddww3Feb 26, 2017Aspirant
Stupid me! I thought the wireless adapter was my flash drive that I had my music on! I did call Netgear and the tech tried to work with me until he finally caught on to the fact that I said it wouldn't assign a drive letter. He did offer support for hundreds of dollars a year, tho. SOrry and best of luck to you!!
- JamesGLMar 13, 2017NETGEAR Employee Retired
Hi All,
The fix will be released early of Q2. If you still have issues with the Windows 10 unable to detect the adapter, please PM me your contact info.
- PreussenMar 13, 2017Initiate
JamesGL,
'Just to confirm - so barring any development hitches, we are going to see Netgear commit to a real fix for the A6210 sometime during the 2nd quarter of 2017?
I hope that is truly the case, because as of now my 2-year old adapter is the most expensive paperweight that I have ever owned - and I am not happy about it.
Please confirm. Thank you.
- stevebarnettMar 14, 2017Aspirant
i totally agree it is a real expensive piece of junk at the moment, will be excellent if they roll out a fix for what was once an excellent bit of gear.
