Soonerdb
Jun 12, 2015Follower
A6210 not supported with Windows 8.1
After several times being hung up on, including while waiting to speak to a supervisor, this is what I've been told. Netgear hardware: R8000 router, E7000 range extender, A6210 wireless adapter ...
- Jul 09, 2015Oh and forgot to mention, I left the adapter plugged in the entire time during the Windows reinstall, then installed the standalone driver.
puffidredz
Jul 10, 2015Aspirant
Annnnd after reinstalling all windows updates, the adapter no longer works at all ... Again. Yea this thing is not stable in 8.1 at all. It works fine as long as u don't update Windows, which is pointless
Dustrega
Oct 18, 2015Star
So, ultimately, why do you keep the post marked as a solution when it doesn't work?
