TrashPuppet
Jan 17, 2020Aspirant
A6210 not working
Hope this is the right forum and sorry for any spelling mistakes, I'm using my phone which has a broke ass screen. My wifi adaptor just completely stopped working. I've previously had issues with it,...
- Jan 17, 2020
1. Windows 7 is dead Upgrade to Windows 10 for free.
2. Does it work on another computer?
3. Try an older version of the driver for the A6210
Tom444
Jan 17, 2020Apprentice
- TrashPuppetJan 17, 2020AspirantYeah I know, I was gonna upgrade this weekend, but can't now.
I don't have any other computers to try it on.
I downloaded the last three updates, but none seem to work.
Every time I reinstall it, it says device not found or the program won't start. I've tried restoring my computer, but I only had a restore point from after the problem started.
Any time i plug in the adapter and my computer tries to automatically install the driver software it doesn't recognise the device/driver not found. - TrashPuppetJan 17, 2020AspirantHoly shyeet! I just went one more update back for the heck of it and it finally worked (??). Thanks for replying, i probably wouldn't have bothered if you hadn't suggested it.
- nauticalMikeFeb 05, 2020Aspirant
I'm on the Windows 10 1909 version, which driver version are you using?
- TrashPuppetFeb 05, 2020AspirantI'd have to check later, but I just downloaded the last three drivers and tried them till one worked.
