omnescient
Jan 09, 2015Aspirant
A6210 operating @ High Speed (USB 2.0)
I've installed A6210 using the standalone Windows 7 driver, and on every boot I receive the W7 message informing me that the device will perform faster when using a SuperSpeed (USB 3.0) port. It i...
- Oct 09, 2015
Hi JamesGL,
I guess this will not help ltj, he most likely doesn't have a problem with A6210 and Windows 10.
His problem - and that of many other customers including me - more likely is the following:
The A6210 works. But only at USB 2.0 speed. Even at USB 3.0 ports.
I will repeat this, just to make the problem clear, once and forever :smileywink:
When using the Netgear driver and plugging the A6210 into USB 3.0 ports
... the A6210 does not connect and work at USB 3.0 SuperSpeed
... it only connects and works at USB 2.0 High-Speed
We purchased an USB 3.0 device. It is advertised as "faster access with USB 3.0". We install the driver. We plug this piece of hardware into an USB 3.0 port. It only works as an USB 2.0 device. The free Tool "USB Device Tree Viewer" confirms this. USB 2.0 speed only. The achieved transfer rates are way too low. As an USB 3.0 device, the A6210 should do much better.
That's the topic of this thread: USB 2.0 speed at USB 3.0 ports.
Luckily, this seems not to be a fundamental hardware problem, but a software / driver problem.
Solution: (that at least worked for me)
- install the standalone version of the Netgear A6210 driver
- stop and disable the Windows service "NetgearSwitchUSB", which is installed and started by the installer
- unplug the A6210
- wait a moment
- reconnect the A6210 to the same USB port.
The A6210 should now be recognized correctly as an USB 3.0 device and will work at SuperSpeed. Hurray!
The service "NetgearSwitchUSB" somehow switches the A6210 via software from USB 3.0 to USB 2.0. If the service is active and you look at the "USB Device Tree Viewer" while plugging the A6210 in, you can see the A6210 shortly and correctly as an USB 3.0 device. But after a second, it disappears and comes back as an USB 2.0 device. Disabling the service prevents this.
How to disable the service (Windows 7):
- Open the Control Panel, click on "System and Security", then "Administrative Tools", then "Services".
- In the list, locate "NetgearSwitchUSB", right click on it, select "Properties"
- Click on the "Stop" button and wait a few seconds
- Click on the drop down menu next to "Startup type" and select "Disabled"
- Click on the "Apply" button
- Click "OK"
- done
I use the A6210 for many month now at USB 3.0 speed without that service active, so it seems not to be mandantory for proper functionality.
Hope that helps.
Bye,
a guy from Germany.
markg14
Aug 19, 2016Aspirant
I thought I'd found the solution to the problem of having my Netgear a6210 not run at USB 3.0 speed, despite being plugged into a USB 3.0 driver. (Just as a side note. I am running Windows 7 and have an Intel Core i7 processor)
1. I downloaded the latest Netgear driver for the A6210 from this Netgear page: http://downloadcenter.netgear.com/en/product/A6210#searchResults
(the latest driver at this time, which I downloaded, is "Software Version 1.0.0.34 (Supports Win10)."
2. I used 7zip file Manager to 'unzip' the download file from Netgear (you can use Winzip or any other unzipping program), I then dragged the downloaded .exe file for the driver to my desktop. (There are actually two .exe files you can choose from once the Netgear download is unzipped. The one with 'SA' at the end means 'stand alone,' meaning no Netgear software is included with it, and it just uses Windows to connect to the USB driver.
3. Unplugged my Netgear adapter from the USB port.
4. Went into my control panel and uninstalled the Netgear software that had already been installed on my computer.
5. Restarted my PC.
6. Double clicked on the Netgear .exe file I'd dragged onto my desktop. Followed the steps on the screen.
7. After the driver installed, it prompted me when to plug in the Netgear adapter, which I did.
8. Then I re-entered my network password.
Voila! Or so I thought. It said Netgeard USB 3.0 adapter installed. I tested my speeds, and they were great. However, I shut down my PC, turned it back on, and the problem came right back. The only way I can get it to go to USB 3.0 speeds is to unplug the adapter from my USB port and then plug it back in (after the computer has finished booting up). Needless to say, this is a pain to have to keep doing every time I turn my PC on.
