omnescient
Jan 09, 2015Aspirant
A6210 operating @ High Speed (USB 2.0)
I've installed A6210 using the standalone Windows 7 driver, and on every boot I receive the W7 message informing me that the device will perform faster when using a SuperSpeed (USB 3.0) port. It i...
- Oct 09, 2015
Hi JamesGL,
I guess this will not help ltj, he most likely doesn't have a problem with A6210 and Windows 10.
His problem - and that of many other customers including me - more likely is the following:
The A6210 works. But only at USB 2.0 speed. Even at USB 3.0 ports.
I will repeat this, just to make the problem clear, once and forever :smileywink:
When using the Netgear driver and plugging the A6210 into USB 3.0 ports
... the A6210 does not connect and work at USB 3.0 SuperSpeed
... it only connects and works at USB 2.0 High-Speed
We purchased an USB 3.0 device. It is advertised as "faster access with USB 3.0". We install the driver. We plug this piece of hardware into an USB 3.0 port. It only works as an USB 2.0 device. The free Tool "USB Device Tree Viewer" confirms this. USB 2.0 speed only. The achieved transfer rates are way too low. As an USB 3.0 device, the A6210 should do much better.
That's the topic of this thread: USB 2.0 speed at USB 3.0 ports.
Luckily, this seems not to be a fundamental hardware problem, but a software / driver problem.
Solution: (that at least worked for me)
- install the standalone version of the Netgear A6210 driver
- stop and disable the Windows service "NetgearSwitchUSB", which is installed and started by the installer
- unplug the A6210
- wait a moment
- reconnect the A6210 to the same USB port.
The A6210 should now be recognized correctly as an USB 3.0 device and will work at SuperSpeed. Hurray!
The service "NetgearSwitchUSB" somehow switches the A6210 via software from USB 3.0 to USB 2.0. If the service is active and you look at the "USB Device Tree Viewer" while plugging the A6210 in, you can see the A6210 shortly and correctly as an USB 3.0 device. But after a second, it disappears and comes back as an USB 2.0 device. Disabling the service prevents this.
How to disable the service (Windows 7):
- Open the Control Panel, click on "System and Security", then "Administrative Tools", then "Services".
- In the list, locate "NetgearSwitchUSB", right click on it, select "Properties"
- Click on the "Stop" button and wait a few seconds
- Click on the drop down menu next to "Startup type" and select "Disabled"
- Click on the "Apply" button
- Click "OK"
- done
I use the A6210 for many month now at USB 3.0 speed without that service active, so it seems not to be mandantory for proper functionality.
Hope that helps.
Bye,
a guy from Germany.
AP10
Feb 16, 2015Novice
Sorry to bump this again, but I've found a solution in case anyone is still having issues.
According to https://wikidevi.com/wiki/Netgear_A6210 the A6210 uses MediaTek's MT7612U drivers, and the chipset vendor and specifications match.
I installed the MT7612U generic drivers from http://www.mediatek.com/en/downloads/usb/ (shows up as '802.11ac Wireless LAN Card' in device manager.) After installing these drivers, USBTreeView now shows the A6210 operating at USB 3.0 SuperSpeed.
- JustRightJul 31, 2015Aspirant
I have just purchased the A6210 for use on Windows 8.1 and eventually Windows 10.
I am using a new X99 chipset based system from ASRock and was amazed that the A6210 would not run at USB 3.0 speed in any of the USB 3.0 ports on the system!!! I was using the most recent genuine NetGear drivers, supposedly suitable for Windows 10 as well. Additionally the ASRock motherboard does not use any third party USB chipsets or hubs, they are all supported directly by the X99 chipset. So I was doubly surprised that the A6210 would not function at it's rather speed.
Anyway I found this thread and have used the newest MediaTek drivers as suggested above, and lo and behold the A6120 now operates at Super Speed USB3.0.
What gives NetGear ??????
