dylanetaft
Dec 24, 2015Follower
A6210 OSX Mac Support
Ah.... Grab the MT7610U driver for OSX http://www.mediatek.com/en/downloads1/downloads/ Run the installer, however the installer is very broken. Have a finder window open, browse to / The ...
CoachCal
Jan 02, 2016Aspirant
I just received a A6210 at Christmas for our Macbook Pro 2010, and Netgear does not have a Mac OS X driver package?
mmomega
Mar 25, 2016Initiate
I actually searched around and found a driver that works for the A6210 in OSX.
I'm currently running 10.11.4
MediaTek is the chipset manufacturer. Chipset is the MT7612U.
So on the below linked page it should be the 2nd listed driver(for OSX) 1st listed is Windows.
I downloaded the driver, installed, restarted and the utility opened almost immediately after restart. Chose a WiFi network, joined and everything seems to working fine.
Now I've only had it installed for literally a few minutes but it's at least working. Only time will tell on how well it works.
- BozeDawgMar 25, 2016Aspirant
mmomega, thanks a ton for this... now I have WiFi on my Hackintosh instead of having to keep it connected via Ethernet.
- bandits1Jun 05, 2016Aspirant
mmomega - thanks for the heads up on the Mediatek driver. Is your adapter still working fine? Do you think the same driver would work with the A6200 USB 2.0 version of the adapter, too?
- mmomegaJun 13, 2016Initiate
The adapter was working fine up until I swapped out desktops about a week and a half ago. I now have a Mac Pro and the antennas in that transmit and receive signal better than the USB adapter did on the Mac Mini so I never tried installing it on the MP.
From what I can tell the A6200 uses a Broadcom BCM43526 chipset. At least in v1.
I also read there may be a v2 out in the wild and that it could be based on the Realtek RTL8812AU chipset.
I would start with a google search with that chipset as part of the search criteria and see what comes up.
Something like "RTL8812AU driver mac" or "BCM43526 driver mac"
This is how I stumbled across the drivers for the A6210.
It just sometimes baffles me knowing that there are legitimate drivers out there to fix issues for people but companies don't make it known or easily accessible.
Hope any of this helps.
- bandits1Jun 24, 2016Aspirant
Thanks again, mmomega, for the useful info. Still debating whether I should gamble on the A6200 or just wait until my current 2011 Mac MIni dies and I buy a new Apple with wireless AC already built in.
- Soft-machineAug 15, 2016Aspirant
That link to the Mediatek download works a treat, not a very elegant front end to the software, but up and working in 5 minutes.
Nice find mmomega.
- lolunity6Dec 08, 2016Aspirant
I downloaded the MT7612U. I apologize for being a newbie, but could you tell me how to install this?
Thanks,
Gary
- FPCApr 20, 2017Initiate
I know what the trouble is, the download link for OSX is shown as Linux, so just download .dmg from https://d86o2zu8ugzlg.cloudfront.net/mediatek-craft/drivers/MT7612_7610U_D5.0.1.25_SDK1.0.2.18_UI5.0.0.27_20151209.zip
but it doesnt seem to work on 10.12.4.
I am having with the OSX drvier downloaded. It is in .tar.bz2, and extract it, it turns to lots files and folders. I tried to compile it with makefile, it returned with error. i would like to learn how to make the installer works. millions thanks!
