aitchie's avatar
aitchie
A6210 Software installation
Good Day
1. How much space (Bytes) does the software for this device require to be installed?
2. Must it be installed on the C:\ Drive, or can it be installed on another logical drive on the hard disc?
Thanks in advance.
aitchie
  • For future users, the answers to my queations ( which I established myself through trial & error) are:
    1. Netgear requires 16.6 MB (17 469 440 bytes) on the hard drive.
    2. Netgear does not give the option to be installed on any but the C:\ Drive.  It can be installed on another logical drive by moving all the files to that drive, then editing the registry - NOT for the faint-hearted.
    Aitchie.
  • Answer 1: If it run out of space, it'll tell.
    Answer 2: Any where you want.
    Just don't plug it in until asked by the install. wizard.
    Good luck.
    • aitchie's avatar
      aitchie
      Thanks VE6CGX.  I don't have a lot of space left on my C:\ Drive, that's why I asked how many bytes the installation uses.
      Aitchie.
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi aitchie,
        I think it is the same MB as the driver. 40-50Mbps will do.
