Spinner4000
Dec 11, 2015Tutor
A6210 Upgrade Failure
Products: A6210 WiFi Adapter Neatgear A6210 Genie The Netgear upgrade process failed and I am unable to perform a "manual" upgrade. The consequence is that the Netgear A6210 Genie no longer wor...
Spinner4000
Dec 20, 2015Tutor
Hi JamesDL,
I tried that (before reporting the problem)... didn't help.
Indeed, nothing I did using answers I found here for similar issues and other "educated guesses" helped...:smileyfrustrated:
Basically, once the automatic upgrade "broke" the software, any and all upgrade/downgrade attempts using the website downloads failed (and left the genie in the non-working state).
I did solve the poblem though... :smileyvery-happy:
I "manually" removed the driver (though could apparerently still not uninstall genie)
Then I used the original CD that came with the product and re-installed successfully.
I then installed the latest version (and got the same apparent failure as described under Initial symptoms above).
However, this time the genie was still working and "help" tells me it is at the latest version...!
JamesGL
Dec 21, 2015NETGEAR Employee Retired
Thank you for the update. Glad to know it works with you.
