NetRider1
Oct 15, 2014Aspirant
A6210 USB 3.0 Adapter
Dear Tech Support... I selected the standalone install which was supposed to be drivers only. But it installed the Genie software as is evedent because it can be uninstalled thru control panel / ...
LDighera
Jan 07, 2015Novice
I would like to use the Netgear AC1200/A6210 USB WiFi adapter on my Windows 8 (64 bit) system without the overhead of Genie.
Windows8 automatically installs the Media Tek, Inc. 5.1.19.0 driver( without Genie).
Previously, I installed the A6210_v1.0.0.28-standalone-signed.exe package I downloaded from Netgear support here. But I would have had to disable a lot of files to get rid of Genie.
Files installed by NETGEAR A6210 Genie:
Program behaviorsBehaviors exhibited:
Service
Hope this helps. LDighera@att.net
A6210.EXE - Genie Application (A6210 Genie MFC Application)
NtgrAdapterUpdate.dll - Netgear Adapter Update Interface (Adapter Update)
NtgrAdapterUpdateOld.dll
ICSDHCP.dll (by Ralink Technology) - ICSDHCP Dynamic Link Library (ICSDHCP DLL)
RaWLAPI.dll - RaWLAPI Dynamic Link Library (RaWLAPI DLL)
Ralink.dll - Ralink Dynamic Link Library (Ralink DLL)
NetgearSwitchUSB.exe - MediatekSw Application
NetgearSwitchUSB-XP.exe
Service
NetgearSwitchUSB.exe runs as a service named 'NetgearSwitchUSB' (NetgearSwitchUSB).
