maltantawi
Oct 24, 2016Tutor
A6210 WiFi Adapter not working
I've had the adapter for about 9 months now working perfectly fine. Yesterday netgear genie auto-updated, and after that, the genie stopped working as a whole. I tried restarting the computer...
olddie
Oct 30, 2016Initiate
I have had this trouble and after searching several forums found an easy solution. Download driver from Mediatek where the A6210 is called MT7612U. Then uninstall Netgear Genie and then plug your dongle back in. In device manager install new driver manually and install Mediatek driver dated 28 Oct 2017 (5.1.22.0). It has worked for me.
mkrakowiak
Nov 02, 2016Aspirant
Olddie's solution did not work for me. Still waiting for an update to the driver that actually works. For now the adapter is useless.
