maltantawi
Oct 24, 2016Tutor
A6210 WiFi Adapter not working
I've had the adapter for about 9 months now working perfectly fine. Yesterday netgear genie auto-updated, and after that, the genie stopped working as a whole. I tried restarting the computer...
mkrakowiak
Nov 04, 2016Aspirant
I tested previous versions of the Netgear driver and was not successful, either, so now I'm beggining to think that recent Windows updates may have broken it. Hopefully Netgear releases a working update soon.
JamesGL
Nov 10, 2016NETGEAR Employee Retired
Hi All,
Please provide me your contact info if you have issues with the Windows 10 update.
JamesGL
Community Team
- maltantawiNov 12, 2016Tutor
As in email?
- drjoshgeidelJan 02, 2017Aspirant
drjoshgeidel@gmail.com
just bought the thing tonight and have been trying for 5 hours now to get my computer to recognize the adapter. I've downloaded so many different drivers and disabled all antivirus and nothing has worked. ready to take it back to the store at this point.
- Glenn1951Jan 03, 2017Apprentice
Try this BEFORE taking it back! This has worked for others and myself, so this is to say it is verified! This is from someone who for lack of better words has been collaborating with me to help people such as yourself! "DO THIS STEP BY STEP IN ORDER"!! In all but a very few cases it's worked!!
The next section is from a poster named koidave:
Ok, I seem to have solved for my machine and wanted to see if it helped others on here with this adapter.
1. Run the file: A6210_v1.0.0.35 and as usual wait for the 'Plug in your adapter' message.
2. When you get the 'Adapter not detected', click Cancel
3. Leave the adapter plugged in, do not remove it and go to Device Manager.
4. Under Network adapters you will see: 802.11ac Wireless LAN Card
5. Double click on this and goto the Driver Tab.
6. Click on 'Update Driver'
7. Now choose 'Browse My computer for Driver Software'
8. Now click, 'Let me choose from a list of device drivers on my computer'
9. Choose Netgear A6210 Wifi usb 3.0 adapter and click Next. The driver will be installed
10. Close down device manager.
11. Go to your wifi / internet iceon in the bottom right of your screen. If you are wired, change this to wireless and then connect to your network.
12. The adapter should now be working
13. I then went to here: http://www.netgear.co.uk/home/discover/apps/genie.aspx?cid=wmt_netgear_organic and downloaded the genie software independently of the A6210 software and installed it.
14. It actually worked and now runs ok under Windows 10 with anniversary. Its a pain, I know, but until Netgear sort themsleves out it works, and to be honest the adapter itself is very good and when connected to my virgin Superhub 2 I'm getting 140mbs download. compared to 10 over my very old powerline adapters.
Hope this helps someone.
Thanks
- dcjamesFeb 11, 2017Aspirant
After installing latist update and plugging in my adapter; it says, "unaable to find the adapter." I have 2 of these adapters and they worked fine until I installed the update.
- Glenn1951Feb 12, 2017Apprentice
Evidently Netgear still hasn't resolved the problem 100% as of yet!! I thought by now they would have pushed a "Update Now" sort of update? This is a PR nightmare!!
Not to sound snotty, but what update?? Did you yourself search for an update or did Genie tell you there was an update?? My problem started with an brand new/ out of box experience. Did you follow ALL the instructions. To properly install adapter software, please remove drivers that were previously installed. Netgear reccommends this!!
To uninstall, go to Start > Programs > NETGEAR A6210 > Uninstall NETGEAR A6210.You're the 1st person in about a month that's had a problem. Netgear sent me a trial version that appears(?) to be what is available online! That worked "FLAWLESSLY"!
If all else fails and you did or will uninstall "ALL" instances of A6210 BEFORE reinstalling it and still encounter problems, go to the post directly above. I'll post it so that when you read my reply it's right there! I KNOW it works as both koidave and myself have verified it. We BOTH had the same problem as you and his post WORKS!! In all but a very, very few "it has worked"!!
P.S. Do not get upset if you see the following for the adapter "Under Properties for the card it showed Driver Provider MediaTek, driver date 4/21/15, driver version 5.1.22.0 This is the same as the Netgear driver!! This one or the Netgear driver work and are the same!!
- dcstaplesMar 04, 2017Initiate
So the KOIDAVE thing above actually works -- but I am not sure you need to do ALL the steps. I think the key thing is this download:
You have to scroll to the bottom of the page where it says "DOWNLOAD PC" and download this. This is a COMPLETELY DIFFERENT PIECE OF SOFTWARE from the usual A6210 download. I am betting my bottom dollar on that is why this all works now. It is a much more complete network analysis and all that -- but the main thing is it actually RUNS on Windows 10 and you can use it to connect to your 5G network via it.
Thanks to all for the research here -- I have been frustrated for 2 weeks since the V.35 update and now it is solved!
- tjastecApr 30, 2017Aspirant
Please provide me your contact info if you have issues with the Windows 10 update"
i am having issues
