Neverwinterx
Aug 29, 2015Follower
A6210 Win8.1 Driver upgrade 1.0.0.32 youtube crashes internet
Just some information for people who may also be having this issue. I have been using my A6210 wifi adapter for months now without problems on Windows 8.1. I had the 1.0.0.30 version installed in st...
JamesGL
Sep 01, 2015NETGEAR Employee Retired
Hi Neverwinterx,
Welcome to Community!
The statement on the release notes under known issue is applicable for users who has Windows 10 OS. If you still have the Windows 8.1, you may disregard it. You can continue to use the current driver that you are using since you do not have any problems with it. If ever you want to use the new driver, try to install it manually instead of doing it automactically.
JamesGL
Community Team
