Nov 27, 2015Aspirant
A6210 Wireless Adapter Keeps Disconnecting
Every 30-40 minutes or so, my A6210 wireless adapter is connected to the router, but not the Internet. This is for around 2-3 minutes before the adapter connects back to the Internet. How do I fix th...
- Dec 01, 2015
If you have anti virus or firewall, try to uninstall it for the meantime and observe the connection. If still the same, I would suggest contacting support.
917
Nov 28, 2015Aspirant
Thanks for replying, JamesGL.
How do I install the standalone driver? While doing this will I have to uninstall the Genie driver?
JamesGL
Nov 29, 2015NETGEAR Employee Retired
Yes, you have to uninstall the Genie driver. The file you have downloaded in support site came with two drivers, the genie and the standalone.
- 917Nov 30, 2015Aspirant
I still get these disconnections, is there another way to resolve the issue?
- JamesGLDec 01, 2015NETGEAR Employee Retired
- david_at_houstoDec 22, 2015Initiate
I had the same problem when 1) using 5G frequency and 2) using the USB 3 port. I now use the 2.4G frequency and USB 2 port. Everything works fine, but I paid for a fast connection and should be able to use it! No other device has an issue with the 5G frequency, only this adapter. My router is the Netgear R6200 v2.
