Nov 27, 2015Aspirant
A6210 Wireless Adapter Keeps Disconnecting
Every 30-40 minutes or so, my A6210 wireless adapter is connected to the router, but not the Internet. This is for around 2-3 minutes before the adapter connects back to the Internet. How do I fix th...
- Dec 01, 2015
If you have anti virus or firewall, try to uninstall it for the meantime and observe the connection. If still the same, I would suggest contacting support.
JamesGL
Dec 01, 2015NETGEAR Employee Retired
david_at_housto
Dec 22, 2015Initiate
I had the same problem when 1) using 5G frequency and 2) using the USB 3 port. I now use the 2.4G frequency and USB 2 port. Everything works fine, but I paid for a fast connection and should be able to use it! No other device has an issue with the 5G frequency, only this adapter. My router is the Netgear R6200 v2.
