daniel_rydell's avatar
May 29, 2019
A6210 Wireless Adapter Keeps Uninstalling
So. I'm out of options, and I'm pretty much out of time.
I have an A6210. I've never had any issues with it. All of the sudden, it's randomly losing its connection to my computer. Not the internet connection; that's a side effect. It is literally saying it is not installed. Yet, when I restart my PC, it finds it. I'm running Windows 10, I know that's the bad sauce when it comes to this wifi adapter, but I'm unable to hardwire right now. I need this working. It seems to lose the adapter no matter what, but when I start a large download is when it seems to happen quicker.
I've got an interview for a work at home job. They're going to want to see my tech setup. I'm normally on top of this. I can't figure out where I'm going wrong, or what's going wrong. I can't easily afford to replace the dongle. Please help.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi daniel_rydell
    Welcome to NETGEAR Community!
    May I know if you already tried to uninstall and reinstall the driver? If not, please do so and install the latest driver 1.0.0.39 https://kb.netgear.com/000058840/A6210-Software-Version-1-0-0-39
    Did you try connecting the adapter to a different USB port?
    How often does the issue re-occur?
    We suggest to do the following steps: Go to Control Panel > Hardware and Sounds > Power options > Change plan settings > USB Settings > USB selective suspend settings > set it to 'Disabled'
    Blanca
    Community Team
    • daniel_rydell's avatar
      daniel_rydell
      Have already done so, had the most up to date driver, still occurred.
      Four different USB ports. Same problem.
      Every few minutes. Only way to correct it is to restart the computer.
       Did that last night, no difference made.
      • Blanca_O's avatar
        Blanca_O
        Hi daniel_rydell
        Our support team is looking into this issue and would like to work with you. Please check you inbox.
        Blanca
        Community Team
