FundRaiserGenie
Feb 22, 2019Aspirant
A7000 USB Adaptor cannot see or detect any network SSID after SLEEP Mode
I was able to install the Netgear Genie and drivers for the A7000 on my Toshiba i7 laptop. My Toshiba is an older but reliable laptop and I wanted faster connectivity.
The initial installation...
ajksldfjalsk
Jun 11, 2024Aspirant
Made a reply to say that this happened to me on the A8000 as well, and I found this post in 2024, but also found a solution.
Please try these steps first:
1. Open CMD with Administrator
2. Type: sc config storsvc type= own ( this resets this service to its default state )
3. Restart the PC.
4. Check if this fixes it.
then also did this:
Right-Click on start button> click device manager> Network adapters>then select the wireless drivers and right-click on it and uninstall the Wifi drivers.
