realdead_man
May 22, 2016Apprentice
ac1200 a6210 windows 10 adhoc hotspot fail
I am trying to create a hotspot on windows 10. I am failing to create a hotspot on windows 10. Server: PC, win10 A6210 card Client Any android device, Nexus 6 Either the client device never...
JamesGL
May 26, 2016NETGEAR Employee Retired
Hi realdead_man,
Is your issue resolved already?
realdead_man
Aug 07, 2016Apprentice
Welp.
Win 10 anniversary (1607) update breaks WIFI HOTSPOT
Nothing I can do to make it work again short of a version rollback.
PS
Netgear has THE **bleep**est drivers I have EVER tried to use.
Always get some kind of error, preventing installation.
- JamesGLAug 12, 2016NETGEAR Employee Retired
Hi realdead_man,
Uninstall and reinstall the driver of the adapter. If you are getting error message when uninstalling, please post the error message or take a screenshot.
JamesGL
Community Team
- realdead_manAug 13, 2016Apprentice
I cant unistall or reinstall the drivers.
I get errors EVERYTIME. 16XX errors. 1605 I think and another.
One errors says in broken engwish, PRODUCT NOT INSTALLED
- JamesGLAug 17, 2016NETGEAR Employee Retired
Hi realdead_man,
If you are having the 1605 error, I would suggest contacting support and inform them about the error message you are gettings.
JamesGL
Community Team
