liortal53's avatar
liortal53
Novice
Nov 29, 2014
AC1200 cannot connect to WIFI network
Hi,
I just got a new AC1200 adapter for my laptop, to be able to connect to a 5 GHZ home network.
My router is a Netgear VEGN2610 (http://www.netgear.com/service-providers/products/telco/gateways/vegn2610.aspx) that is dual-band and has 2 networks - 2.4 and 5 ghz.
I have installed latest drivers from the internet (using Windows 8.1).
When attempting to connect i am getting VERY LOW signal for the 5ghz network, and the connection fails.
The 2.4ghz network is about the same performance as the one with the internal wifi adapter of my laptop (Dell XPS 17 L702x).
What's going on ? i assumed 5ghz and the latest WIFI standards should offer better range and performance. Why isn't it working ?
I wanted to consult with the forums before i contact Amazon to return the product.
1 Reply
  • First - you need to understand that to utilize the latest WiFi standards - BOTH ENDS - ie the router and the client MUST meet those standards, an 802.11n router (which is what you have) with an 802.11ac client will not, can not, deliver anything better than 802.11n performance. A Dell XPS17 should ship with an 802.11n wireless card, so you can expect 802.11n performance there, and there's no reason to expect that switching to a Netgear client would provide any significant improvement in performance. Second - due to the laws of physics - higher frequency transmissions suffer attenuation to a greater degree - 5GHz networks will generally have less range than 2.4 GHz networks - depending on your distance from the router and also what lies in between your laptop and the router - your very low 5GHz signal strength may or may not be expected.
