cyndane
Jul 28, 2016Aspirant
AC1200 USB WiFi Adapter - Intel/AMD
Simple question: I was looking at the specs on this USB adapter and it stated it is for a "Pentium Class PC". Am I right (or wrong) to assume that this will not work on a PC that uses an AMD pro...
- Jul 28, 2016
Hi Cyndane,
"Pentium Class PC" is a chip classification that was produce 1995 onwards and AMD is part of it. So the answer to your question is it should work with the AMD processor.
JamesGL
Community Team
VE6CGX
Jul 28, 2016Master
I think you misread it. It is minimum requirement to use that adapter. If AMD cpu/APU has same level of performance level wny not? Also there is minimum amount of memory requirement in addtion.
