Highriser
Nov 21, 2023Aspirant
AC19000 USB Adapter constantly getting high ping spikes
I have a AC1900 USB adapter for 2 months now and it has been acting up for the last two weeks. Started out by dropping connection at random times, but I fix that with CMD. Now it shows I getting 200 ...
michaelkenward
Nov 22, 2023Guru - Experienced User
Highriser wrote:
All my driver are up to date and it's not the router as I have tried two different adapter that have worked perfectly fine with my computer.
Not really a guarantee of anything. Your other adapters will use different drivers. And Windows will see them all as different devices.
Windows is very good at blocking Internet access when it sees something new on the network.
I have tried using the Netgear adapter on another computer that is on a whole different internet service and it still gave the same problem.
It is still in the warranty period so it might be worth an RMA,
Of course, the usual advice is that using wifi to play games is, as they put it, a mug's game.
Highriser
Nov 24, 2023Aspirant
Since I have no other option when it comes to internet, I thought getting the top of the line adapter would help. I guess not if anything it made the problem worse.
- michaelkenwardNov 25, 2023Guru - Experienced User
If you want help, you will have to tell us a bit more about what is happening at your end.
We do not know what wifi source the adaptor connects to. We don't know if you installed Netgear's drivers or the Genie software that comes with the drivers. Some people leave Netgear out of it altogether and use the native drivers that come with Windows.
You say that other adapters work OK, but as you have discovered not all adapters are born equal. So one might work while the other needs some tweaking.
We know nothing about the device that you adapter is plugged into, merely that you think that the drivers are up to date. As anyone who has fought Windows will tell you, that can be a beast to tame.
While I use USB adapters, for serious wifi I have installed a WiFi 6 PCI-e card in my PC. Id delivers, 2.4 Ghz , 5 Ghz and 6 GHz wifi as well as bluetooth. It did not cost me $90.
I do not do any gaming. But if I did I would investigate the use of Powerline Ethernet. I find that it is more reliable than wifi, perhaps even faster. I use it to connect wireless access points to my main router
