dzerzhinsky
Aug 13, 2014Aspirant
Adapter constantly switches to N
Our Netgear router is broadcasting both N and AC networks, yet my adapter routinely decides it wants to connect exclusively to the N network. I can, of course, manually disconnect then reconnect to A...
dzerzhinsky
Aug 14, 2014Aspirant
I have to assume you are using two different SSIDs for the two different standards
*facepalm* no, I'm not. I didn't even know that was possible.
I also wasn't aware that n supported 5GHz, guess you're correct, I do need to edumacate myself a little more on the standards. One glaring question that leaps to mind is why ac is considered "better" than n if they both support 5GHz?
