dzerzhinsky
Aug 13, 2014Aspirant
Adapter constantly switches to N
Our Netgear router is broadcasting both N and AC networks, yet my adapter routinely decides it wants to connect exclusively to the N network. I can, of course, manually disconnect then reconnect to A...
fordem
Aug 14, 2014Mentor
ac allows higher theoretical throughput.
Tell me - if you're not using different SSIDs, how do you know whether you're connected to n or ac?
