AnthonyMa
Dec 31, 2016Guide
Adapter isn't detected
When prompted to plug in the adapter for it to scan I did. But when it scanned for the adapter, it would never find it. I tried with the newest version and with the version that is downloaded through ...
- Dec 31, 2016Turns out, the software is just broken. I just connected the internet and tested it. It seems to be working fine. Don't bother with the software if you are having the same problem
AnthonyMa
Dec 31, 2016Guide
It is the Netgear A6210 and I have windows 10
Trikein
Dec 31, 2016Luminary
Have you tried downloading and running the latest software? Looks like only 1.0.0.32+ supports Windows 10. See here.
Also, what are you plugging it into? A laptop? Desktop? Have you tried different USB ports? Finally, when you plug it in, does the PC reconize the USB insert at all, like with a sound or icon?
