AnthonyMa
Dec 31, 2016Guide
Adapter isn't detected
When prompted to plug in the adapter for it to scan I did. But when it scanned for the adapter, it would never find it. I tried with the newest version and with the version that is downloaded through ...
- Dec 31, 2016Turns out, the software is just broken. I just connected the internet and tested it. It seems to be working fine. Don't bother with the software if you are having the same problem
AnthonyMa
Dec 31, 2016Guide
Yes I have used windows 10 compatible versions and I have tried using different ports on my desktop
