AnthonyMa
Dec 31, 2016Guide
Adapter isn't detected
When prompted to plug in the adapter for it to scan I did. But when it scanned for the adapter, it would never find it. I tried with the newest version and with the version that is downloaded through ...
- Dec 31, 2016Turns out, the software is just broken. I just connected the internet and tested it. It seems to be working fine. Don't bother with the software if you are having the same problem
AnthonyMa
Dec 31, 2016Guide
It the computer sees it because it gives me the option to connect to the internet in the network settings
Trikein
Dec 31, 2016Luminary
Odd. I am sorry, but I am running out of ideas. It is odd that the PC can see the adapter but the software can't. Do you have any Antivirus you can try disabling? Do you notice any popups or warnings from anything on your computer when running the software?
Also, would you happen to had use a simular adapter on this PC before? Wondering if maybe a old driver is auto-installing which is breaking it.
Anyone else have any ideas?
