AnthonyMa
Dec 31, 2016Guide
Adapter isn't detected
When prompted to plug in the adapter for it to scan I did. But when it scanned for the adapter, it would never find it. I tried with the newest version and with the version that is downloaded through ...
- Dec 31, 2016Turns out, the software is just broken. I just connected the internet and tested it. It seems to be working fine. Don't bother with the software if you are having the same problem
AnthonyMa
Dec 31, 2016Guide
Also the software is on a solid state drive should I try to install it on a normal hard drive
Trikein
Dec 31, 2016Luminary
You can try, but as long as your installing it on the same HD as the OS, you should be fine. Even if you weren't, I don't understand how it would cause this problem. A problem with installing the driver for the adapter maybe, but the software should atleast see the adapter. I guess it can't hurt to try though. Can you try on a different computer too?
