AnthonyMa
Dec 31, 2016Guide
Adapter isn't detected
When prompted to plug in the adapter for it to scan I did. But when it scanned for the adapter, it would never find it. I tried with the newest version and with the version that is downloaded through ...
- Dec 31, 2016Turns out, the software is just broken. I just connected the internet and tested it. It seems to be working fine. Don't bother with the software if you are having the same problem
AnthonyMa
Dec 31, 2016Guide
Nothing is working this is ridiculous. AVG isn't blocking it as far as I'm concerned and even without driver signature enforcement enabled, it still refuses to detect it.
