AnthonyMa
Dec 31, 2016Guide
Adapter isn't detected
When prompted to plug in the adapter for it to scan I did. But when it scanned for the adapter, it would never find it. I tried with the newest version and with the version that is downloaded through ...
- Dec 31, 2016Turns out, the software is just broken. I just connected the internet and tested it. It seems to be working fine. Don't bother with the software if you are having the same problem
AnthonyMa
Dec 31, 2016Guide
- TrikeinDec 31, 2016Luminary
Good to know. I wonder why the old software worked when the new software wouldn't. Also, what does the software do? I have never used a Netgear USB adapter. Does the software just install the USB driver or does it help with configuration? If so, and if it installs a seperate wireless client, then I wonder if that client is conflicting with Windowws Wireless Zero (default wireless client) or what ever it is called with Windows 10. Either way, you are better off using the standard windows wireless client instead of a 3rd party (Netgear), so maybe it's a blessing in disguise.
