Walt_Mayhew's avatar
Walt_Mayhew
Follower
Mar 12, 2016
Bad Pool Header WiFi adapter wnda3100
I recently instsalled Windows 10 and everything works great until I try to connect to the internet using my Netgear WiFi adapter (WNDA3100 Model). When I do within seconds I get a blue screen of death and the message that the cause is a Bad Pool Header. I used a second computer to find Windows 10 drivers for the adapter which I downloaded and installed to the computer. Unfortuately I would up with the same problem. Not sure what to try at this point to fix the problem.
1 Reply
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Walt_Mayhew,
    Is it WNDA3100v1? if yes, the adapter does not support Windows 10. Please double check the version of the adapter.
