jakabdsig
Dec 03, 2012Follower
Best setting for maximum performance?
I just got the Netgear a600 wireless usb router. In advanced options, what would be the ideal setting for the best distance and best speeds and consistency(keeping hold of acess point) for the dev...
Retired_Member
Jan 16, 2014You may get a response if you correctly identify your device. Bumping actually could cause your post to be ignored. After several searches to find a600 I gave up, not going to guess which device OP actually has.
