JazzMac251
Sep 26, 2015Aspirant
Cannot Create Hosted Network (Ad Hoc) with A6210 Adapter
W10 Pro Intel Compute Stick netsh wlan start hostednetwork The hosted network couldn't be started. The group or resource is not in the correct state to perform the requested operation. The ne...
JazzMac251
Sep 30, 2015Aspirant
Including netsh wlan start hostednetwork? Everything works for me up to that point. Trying to actually start the network retuns the error I posted in the OP.
If you can start your hosted network, what driver are you on? Does your Device Manager show Microsoft Hosted Network Virtual Adapter AND Microsoft Hosted Network Virtual Adapter #2 or is there just one (make sure to go View --> Show Hidden Devices to see the virtual devices)? Is the AC6210 your only adapter? If not, are your others disabled?
I've tried everything I can think of to get this working. There must be a reason this works on your machine but not mine (assuming it does).
JazzMac251
Oct 02, 2015Aspirant
Any news on this?
- JamesGLOct 07, 2015NETGEAR Employee Retired
Hi JazzMac251,
I followed the link provided by storm1985 and I was able to create an Adhoc network.
JamesGL
Community Team
- JazzMac251Oct 07, 2015Aspirant
Hi,
Thanks for your reply. Any idea why I'm not able to start my network with this adapter? I would really like to keep/use it.
Thanks!- JamesGLOct 08, 2015NETGEAR Employee Retired
Hi JazzMac251,
Can you configure it again using the link that storm1985 provided. All I did was just follow the steps on it.
JamesGL
Community Team
