Olegrius
Feb 20, 2013Aspirant
Don't connect 1300 Mbit/s 802.11ac
Hello! Windows 7 64bit Ultimate, router R6300 (last update). I can't connect to the 5GHz with A6200 when in the spped settings of router is 1300 Mbit/s. Status of IPv4 - no internet access, IPv...
Anvial
Mar 31, 2013Aspirant
It seems I solve the problem.
I set up 5 GHz netowork to 600 Mbit/s, and connect ro ir normally.
Then I turn on the Guest (5 GHz) network, and connect to it. The connection was successful.
From the Guest (5 GHz) network I change ro 1300 Mbit/s and after that I can connect to it.
May be this way will be helpful to you, too.
