petitorme
Aug 22, 2015Follower
Driver Windows 10 pour carte WIFI NETGEAR WN311T
je ne trouve pas le de drivers pour carte WIfi WN311T - 100FSS Netgear pour fonctionner sous W10 ?
Et j'ai acheté 2 cartes de ce type S/N : 1K8171L90130F et TA: 100-12364-01R15 !
Je n'ai trouvé que la version très ancienne sur le site Netgear (WN311T Driver and Utility Version 4.2)
S’il vous plaît ?
I can not find drivers for the card WIfi WN311T - 100FSS Netgear to run on W10?
And I bought 2 cards of this type S / N: 1K8171L90130F and TA: 100-12364-01R15!
I found that the very old version of the site Netgear (WN311T Driver and Utility version 4.2)
If you please ?
1 Reply
- JamesGLNETGEAR Employee Retired
Hi petitorme,
Welcome to Community!
This type of adapter are part of EOL products of NETGEAR which most likely will work with earlier OS versions. The software it has can only support upto Windows Vista and even Windows 7 is no longer supporting it. I recommend you to purchase NETGEAR adapter that will work with Windows 10. You may check the link below for the list of adapters that will work with Windows 10.
JamesGL
Community Team
