WalterDH
Jan 23, 2016Aspirant
Entering password to connect MA101 adapter to R4500 router.
The adapter recognizes the SSID of the router, but I don't see how/where to enter the network password. The adapter's configuration utility (Security tab) allows me to enable encryption (WEP) and ent...
WalterDH
Jan 24, 2016Aspirant
Thanks for the info. I'm willing to risk a very brief period of no security. But turning off encryption on the MA101 and on the R4500 didn't allow the MA101 to connect. It sees the SSID of the router, but apparently doesn't communicate through it; I can't do a successful ping. Any ideas short of replacing the MA101? (It's on a very old PC that has some special purpose software I use occasionally.)
TheEther
Jan 25, 2016Guru
Try lowering the 2.4 GHz wireless mode to Up to 54 Mbps in Wireless Setup on the R4500. This should open up access to 802.11b devices.
