Bleurk
Jul 16, 2014Aspirant
Failed to join wireless network
It seems I am not alone. I have tried everything suggested in previous posts and am getting nowhere. A6200 wifi adapter refuses to connect to recently acquired D6200 router. Router works fine for 2.4...
Bleurk
Jul 24, 2014Aspirant
Distance is about 6 feet. I am clear that the PC can 'see' the router as windows reports the router as being present with a signal strength of 'fair'.
Netgear support have swapped the adapter for a replacement A6200 - 100WWB.
And that gives exactly the same results.
ie 2.4G N works well and is very stable.
5G AC - 'Failed to join network'
I have tried various channels and various speed settings on the router and no improvement.
Does anyone actually have one of these that works?
