Schwarzoid
Jul 31, 2017Aspirant
Fresh Win 10 install BSOD upon connection to network A6210
Hello Everyone, So I just updated a home PC from windows 7 to windows 10 and did a 100% clean install. When trying to connect to a network, I get a BSOD as soon as click connect to network a...
- Aug 06, 2017
I ended up being able to fix it on my own.
I went into the device manager and uninstalled all the known drivers and hardware from the PC.
I then downloaded the most recent drivers onto a thumb drive and installed the drives through that into the PC and I was able to connect to the network without getting a BSOD
Schwarzoid
Aug 06, 2017Aspirant
- michaelkenwardAug 07, 2017Guru - Experienced User
Well done.
Like I said at the beginning, and as you have confirmed, Windows may not have the best drivers when you first install it.
Part of the problem is that it tries to use its own generic drivers rather than those written specifically for the hardware.
A common area where this happens seems to be LAN drivers. It is often better to get them from the chipset maker, or whoever made the motherboard with that LAN function.
You might like to mark your answer as Solved to help other people to find the solution when they turn up with a similar issue.
