jape
Dec 28, 2016Follower
Genie unable to detect adaptor
Hi, Recently destroyed my old USB adapter to my computer which has had windows 10 since I got it. So bought the N300, installed from CD but when it comes to detecting the adapter it simply doesn'...
- Jan 03, 2017
Hi jape,
Download the latest driver from support site.
https://www.netgear.com/support/?cid=wmt_netgear_organic
When installing the driver, disable first any antivirus installed on your computer.
JamesGL
Jan 06, 2017NETGEAR Employee Retired
Hi jape,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
