KellyKat3737
Dec 02, 2015Follower
Help Installation with AC1200 High Gain Wifi USB Adapter to a Smart Samsung UN60D6000SF
Help Installation with AC1200 High Gain Wifi USB Adapter to a Smart Samsung UN60D6000SF.
Thank you and I hope I hear from someone, I've been on hold with Netgear over 30 minutes.
Kelly
1 Reply
- DexterJBNETGEAR Moderator
Hi KellyKat3737,
NETGEAR wireless USB adapters can only be used for Windows computers since it will require installing device drivers. I believe your Samsung TV will require a specific Samsung USB adapter as indicated on the user manual for it. You may refer to the link below for the user manual of your TV on page 81.
http://downloadcenter.samsung.com/content/UM/201103/20110324091218633/[ENG_US]GSATSCA-1017.pdf
Dexter
Community Team
