soccer0104
Oct 29, 2012Aspirant
Help with install please
I installed the driver and when the genie says to insert the adapter i do and i get lights but then i get this error:
The NETGEAR A6200 WiFi Adapter is not found. Please Help!!!
- macsmakerAspirant
jmizoguchi wrote: make sure you are not using USB ports used by other USB device
USB port are paired in block. two USB ports per block so try different USB ports.
If something is not plugged to it, how can a USB port be in use?
