CMcD
Dec 03, 2018Aspirant
Huawei wifi E5573C connection failure
Just bought and install the A6210 WIFI Adapter. It detects the signal from my Huawei E5573C and asks me to enter the security key to connect to the network (Wuawei), when I enter the security code I ...
Blanca_O
Dec 09, 2018NETGEAR Employee Retired
Hi CMcD
Welcome to NETGEAR Community!
Please be reminded that password is case sensitive. We just want to make sure that we entered the correct password. Kindly check as well if you have Access Control enabled on your router.
Blanca
Community Team
- CMcDDec 10, 2018AspirantThanks fir the reply.
I am putting the correct password in ok, its actually a numeric one. I am just starting to wonder if the Netgear afaptr is faulty in some wsy.
