Schyler
May 18, 2015Aspirant
Losing Packets
I have the A6210 WIFI adapter and I am experiencing packet loss. This just started. I have tried updating and everything but it just lags to hell. Please help!
Schyler
May 29, 2015Aspirant
minions08 wrote: Can you try to Ping as well your router and see if it has packet loss. Do you get the same problem using a different device?
Yeah I had the same exact problem.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\asus>ping 10.0.0.1 -t
Pinging 10.0.0.1 with 32 bytes of data:
Reply from 10.0.0.1: bytes=32 time=1115ms TTL=64
Reply from 10.0.0.1: bytes=32 time=11ms TTL=64
Reply from 10.0.0.1: bytes=32 time=5ms TTL=64
Reply from 10.0.0.1: bytes=32 time=1ms TTL=64
Reply from 10.0.0.1: bytes=32 time<1ms TTL=64
Request timed out.
Reply from 10.0.0.1: bytes=32 time=1622ms TTL=64
Ping statistics for 10.0.0.1:
Packets: Sent = 16, Received = 15, Lost = 1 (6% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1622ms, Average = 184ms
Control-C
