Neil_Con
Oct 15, 2017Aspirant
Lost installation CD
I purchased the above router many years ago, and just recently decided to try using it again. The only problem is i cannot find my resource cd, and cant set up the router. Is there a link to the relevant router software? Thanks
- Routers don't really need installation CDs. You can configure them with a web browser. Go to support.netgear.com and type in the model number. You can download the online manual which will contain instructions on setting up your router.
- Neil_ConAspirantDownloaded the manual, but it says i need to set up using the set-up wizard (which if i recall, was on the resource cd)
You haven't said which device you are using – I see no "above router" – but most manuals will tell you how to do a manual setup.
The quick start/installation guides are less helpful on that front.
For more advice, tell us the model number on your device.
Neil_Con wrote:
I purchased the above router many years ago...You have posted this message in a forum section dedicated to WiFi Adapters.
