KarterJK
Apr 21, 2013Novice
My A6200 with R6300 setup guide windows 7 & 8
We have been running the Netgear R6300 and the Netgear A6200 WiFi Adapter about a month now Comcast is our ISP, and our home network combines; 4 wired windows 7 units 1 wifi windows 7 machine wi...
Strife2211
May 13, 2013Aspirant
That is correct J. But transfer rates are measured differently between telecommunications (mbps) and computer components (megabits). megabyte: megabit: a unit of information equal to 1000 kilobits For example, the abbreviation 2 Mb can actually be expanded in 4 different ways (mega- vs mebi- and -bit vs -byte). The difference in the two totals can be huge. "b" stands for bit and B stands for byte. One byte refers to 8 bits. When a 1 Mb/s connection is advertised, it usually means that the maximum achievable download bandwidth is 1 megabit/s (million bits per second), which is actually 0.125 MB/s (megabyte per second), or about 0.1192 MiB/s (mebibyte per second).
jmizoguchi wrote: I think I read last week with USB2.0 gotten over 480Mbps (over 2.0 spec)
