martingc
Oct 14, 2015Initiate
My A6200 wont turn on when i connect it to my computer
In March earlier this year I had bought a A6200 WIFI adapter for my schooling as my computer doesn't connect to their WiFi and it's a very technology based school. When I plug in the adapter straight to my computer the light always goes on straight away, a few times it turns off though and I have to unplug and plug it back in to get it working again. Last night though I was using it perfectly fine and today it hasn't turned on at all when plugged into my computer. I have restarted and shut down my computer multiple times but sti the light doesn't turn on. My computer is a Lenovo yoga 2 11 and is updated to Windows 10. If anyone can help that would be great thanks.
Do you have the Windows 10 drivers installed? You can download them from http://downloadcenter.netgear.com/en/product/A6200#searchResults.
To be safe, uninstall the old drivers before you install the new ones.
- martingcInitiate
Thank you so much! It started working as soon as I plugged it in with newer version for my computer. This has been such a good help thank you!
