Ubuz239's avatar
Ubuz239
N300 Wifi USB adapter
The setup went smoothly until I tried to enter our password for our home network. I could not enter a single digit. So I tried pressing the button on the cradle as the Netgear genie instructed. It found my network but never connected, though I tried repeatedly.
  • Hi Ubuz239,
    Are you trying to use the Genie software to connect to the network or the Windows utiltity?
    What is the OS version of your computer?
    What is the model number of your adapter?
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Ubuz239,
    • Ubuz239's avatar
      Ubuz239
      Thank you for responding. I am such an idiot. I had two keyboards in front of me and forgot to use the correct one. It works just fine. Sorry to waste your time.
