AJ-711
Aug 14, 2021Tutor
Need advice on what type of USB 3.0 extension to use w/Nighthawk Dual-Band USB 3.0 Adapter
Maybe I can't put an extension on this adapter but I would like to get it up higher out from behind my monitors...I did have what I thought to be a USB 3.0 6.6ft Extension Cable with high reviews fro...
Aug 14, 2021Guru - Experienced User
Have you tried a different cable?
In my experience it tends to be a cable quality issue if you're having problems with a cord under 10ft.
AJ-711
Aug 14, 2021Tutor
No I haven't I was going to but I would need to purchase another...That's why I came here to see if anyone had any suggestions? If not, I will take another shot at a highly rated one on Amazon & see what happens.
