mbkitmgr3
Aug 06, 2024Aspirant
Netgear A6100 Wifi adpaters dropping out
I have a client that has approx 12 desktops all running Windows 10 and connected to their Wireless via Netgear AC600 USB adapters. They report and I have experienced them devices frequently dropp...
michaelkenward
Aug 07, 2024Guru - Experienced User
That's a lot of devices using a pretty basic USB adapter to connect to the network.It first came out in 2013, long before Windows 10.
Is the main router up to that load?
Just another user with time on their hands.
mbkitmgr3
Aug 07, 2024Aspirant
Yes, the Cisco is up to the task as is the Meraki AP's. It seems to not matter if a device is connected to the business WLAN or tethered to a hot-spot they still see the devices drop off. The client bought them - certainly not the product or setup I would recommend.
