loldongslol
Mar 06, 2013Aspirant
Netgear A6200 cannot see 5GHz Network from ASUS RT-N66U
I recently purchased an Asus RT-N66U which I'm very excited about. I also picked up a Netgear A6200 USB WiFi adapter. It's 802.11ac Dual Band compatible (says so on the box). When I set up the router...
Mark_K
Mar 06, 2013Tutor
did you follow the intsall instuctions to follow the order of when to install the SW and when to plug the adaptor in?
Also make sure your built-in WiFi card is disabled.
